OKsoccer24 Posted August 15, 2003 Report Posted August 15, 2003 I was wondering on differences between sand devils and haulers (8 paddles). The only difference I know of is devils are $35 and haulers are $70. Quote
Dragg-on Posted August 15, 2003 Report Posted August 15, 2003 Most dragsters use haulers, and wouldnt be caught dead w/ anything else Quote
Chemical Castration Posted August 15, 2003 Report Posted August 15, 2003 Haulers will hook better than sand devils. If you want all the performance you can get, dont skimp out on the tires, no point in having all of that power if you cant get it to the ground. Quote
alcoholbanshee Posted August 15, 2003 Report Posted August 15, 2003 I have never seen anything at the drags but haulers and probably never will. They are awesome. Quote
Screamin_Banshee Posted August 15, 2003 Report Posted August 15, 2003 Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers,Haulers, Haulers, Haulers Get the point? Haulers will hook up better than Sand Devils in any sandy terrain. Dont skimp on tires if your goin to be draggin. Quote
WickedBanshee Posted August 15, 2003 Report Posted August 15, 2003 in most cases, haulers are the best tire you can get for sand dragging. however, setup is EVERYTHING!!!!! if you get the round haulers, they are the best. but if you get the flat kind, they arent that good. we had a set of the flat ones and a set of geckos and sand sharks. w/ the flat haulers you'd come barreling out of the hole like 4 bikes ahead of the others. but since they are flat, there isnt much top end and alot more paddle is getting to the ground which puts a bigger load on the motor in the higher gears. the sand sharks and even the geckos would catch up in the end because of the rounder shape and less paddle getting to the ground. geckos suck ass. i'd say for a piped banshee, sand sharks are a damn good tire and i am very impressed w/ them. but if you got porting go for 21x12x8 10 paddle haulers. Quote
WickedBanshee Posted August 16, 2003 Report Posted August 16, 2003 in most cases, haulers are the best tire you can get for sand dragging. however, setup is EVERYTHING!!!!! if you get the round haulers, they are the best. but if you get the flat kind, they arent that good. we had a set of the flat ones and a set of geckos and sand sharks. w/ the flat haulers you'd come barreling out of the hole like 4 bikes ahead of the others. but since they are flat, there isnt much top end and alot more paddle is getting to the ground which puts a bigger load on the motor in the higher gears. the sand sharks and even the geckos would catch up in the end because of the rounder shape and less paddle getting to the ground. geckos suck ass. i'd say for a piped banshee, sand sharks are a damn good tire and i am very impressed w/ them. but if you got porting go for 21x12x8 10 paddle haulers. Quote
Strm Trpr Posted August 6, 2011 Report Posted August 6, 2011 in most cases, haulers are the best tire you can get for sand dragging. however, setup is EVERYTHING!!!!! if you get the round haulers, they are the best. but if you get the flat kind, they arent that good. we had a set of the flat ones and a set of geckos and sand sharks. w/ the flat haulers you'd come barreling out of the hole like 4 bikes ahead of the others. but since they are flat, there isnt much top end and alot more paddle is getting to the ground which puts a bigger load on the motor in the higher gears. the sand sharks and even the geckos would catch up in the end because of the rounder shape and less paddle getting to the ground. geckos suck ass. i'd say for a piped banshee, sand sharks are a damn good tire and i am very impressed w/ them. but if you got porting go for 21x12x8 10 paddle haulers. What width 8" rim would best fit the 21x12x8 10 paddle hauler? 8x8 8x9 8x10 Quote
camatv Posted August 15, 2011 Report Posted August 15, 2011 sand devils are the bestest paddlels eva! Quote
Josh Z Posted August 15, 2011 Report Posted August 15, 2011 sand devils are the bestest paddlels eva! right after sand geckos tho!!!! Quote
camatv Posted August 27, 2011 Report Posted August 27, 2011 is this one of the oldest posts left? Quote
