AKRACIN Posted February 2, 2011 Report Posted February 2, 2011 Hello This is the first post for me here and new to banshees. I am having an issue with my banshee, under hard acceleration im getting a kinda ratcheting feel n sound coming from what I think is the trans, The clutch does not feel as if its slipping at all, does anyone have any input on where i begin looking for the culprit? I am unsure of the year or the mods I do know it has jcs on the side of the cylinders, fmf pipes, kool head, 36mm carbs. This machine is faster than my other quads by far( bolt on modded trx 450, 488 athena yfz, ported fmf pipped 28mm carbed shee) I am Ice racing 1/4 mile if that helps at all. Thank you in advance. Quote
n2otoofast4u Posted February 2, 2011 Report Posted February 2, 2011 More than likely the chain is skipping.. Check your sprockets as well as your chain tension... Be sure to check your sprocket hub is tight on your axle as well.. Quote
AKRACIN Posted February 2, 2011 Author Report Posted February 2, 2011 More than likely the chain is skipping.. Check your sprockets as well as your chain tension... Be sure to check your sprocket hub is tight on your axle as well.. Thats the first thing I checked all looks good there. That is what it feels like a toothless sprocket. this thing pulls like mad even with this feel/sound in it. Thank you for the response what should i check next? Quote
Larry's Shee Posted February 2, 2011 Report Posted February 2, 2011 (edited) Does it do it in all gears? Put the axle up on something , put trans in first gear, try rolling wheels foreward and backwards enough to the point just before engine turns over (make sure ignition is OFF) , checking for your "skipp". Then pull plugs, and roll engine over in each gear. Could be broken gear in trans or primary reduction. (or tooth) Edited February 2, 2011 by Larry's Shee Quote
bansheesrtoys Posted February 2, 2011 Report Posted February 2, 2011 (edited) i had the same problem with a brand new primary drive sproket. it wasn't so bad at first but after a few long rides the rear sproket had 4 missing teeth, and most of the rest looked like a shark fine. When it first started it was mostly WOT. check each tooth on the rear sproket real close. roll it on the ground and see it the chain gets cuaght on the rear sproket. when you are down there look at the rollers and front chain slide too. the stock frot slide is junk and when it goes out the chain will eat into your swingarm. just worth a look. Edited February 2, 2011 by bansheesrtoys Quote
AKRACIN Posted February 2, 2011 Author Report Posted February 2, 2011 Does it do it in all gears? Put the axle up on something , put trans in first gear, try rolling wheels foreward and backwards enough to the point just before engine turns over (make sure ignition is OFF) , checking for your "skipp". Then pull plugs, and roll engine over in each gear. Could be broken gear in trans or primary reduction. (or tooth) It only does it in the top of 4th and 5th gear under full throttle acceleration. I will try the free wheel method on a jack stand and see what i get. thank you very much Quote
AKRACIN Posted February 2, 2011 Author Report Posted February 2, 2011 i had the same problem with a brand new primary drive sproket. it wasn't so bad at first but after a few long rides the rear sproket had 4 missing teeth, and most of the rest looked like a shark fine. When it first started it was mostly WOT. check each tooth on the rear sproket real close. roll it on the ground and see it the chain gets cuaght on the rear sproket. when you are down there look at the rollers and front chain slide too. the stock frot slide is junk and when it goes out the chain will eat into your swingarm. just worth a look. My chain and sprockets are in great shape not many miles on them, thanks Quote
Rustynail Posted February 16, 2011 Report Posted February 16, 2011 I Am having a simillar sound and feel on mine...I havent had time to look at it but ill let u know when i figure it out. Quote
sangheraent Posted February 17, 2011 Report Posted February 17, 2011 Mine made ratchiing sounds as well. it was the axle bearings shot to shit. sounded like the chain skipping but my sprockets were in perfect condition and I had a new chain that was tight. the bike when jacked up the rear tires spun perfectly and for a long time seemed like the bearings were good. but when I opened it up they were dry and worn original 1994 bearings. Quote
