use this search to find porting threads, its better than the search on the top right. http://bansheehq.com/forums/index.php?app=core&module=search
if it where a 4 stroke, yeh shaw give it a go. but its a 2 stroke and totally different so unless you have the slightest idea on what needs to be done, dont touch it. and get a pro to do it.
A general cleanup port can be done at home no problem. Smooth out intake runners, remove casting flaws, sand and polish the exhaust port... It can be done at home. As for changing angles or port window heights... leave it to the pro's. Give kevin at HJR a call. He does some awesome port work. Very professional guy.
X2 leave it to a pro. There is alot more to know than just taking a dremel to your cylinders.
