Unscrew the carb top, take out the slide, the center part of the carb slide ( where the cable attaches) will unscrew (has a hex top) and should be able remove needle, and last but not least..Downsize your pic in your sig... ;)
can some one tell me what the float hights should be on 35 pwks.and also the best way to set them
I believe its 16mm. You tilt the carb on its side to measure from the carb body (where the gasket would go if it had one) and make sure the metal tang is just touching the needle & seat (without compressing it) while measuring to the bottom of the float.
http://scootrs.com/tech.cfm?tip=float
Edited by sprinklerman
