banshee 268 Posted January 17, 2011 Report Share Posted January 17, 2011 i have a set 35 pwk carbs and was wondering how do i get the needles out to see if i can adjust them. Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted January 17, 2011 Report Share Posted January 17, 2011 Unscrew the carb top, take out the slide, the center part of the carb slide ( where the cable attaches) will unscrew (has a hex top) and should be able remove needle, and last but not least..Downsize your pic in your sig... Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted January 17, 2011 Author Report Share Posted January 17, 2011 k thanks for the info and how do i down size the pic Quote Link to comment Share on other sites More sharing options...
RZBansheeMan Posted January 17, 2011 Report Share Posted January 17, 2011 Upload it to "Photobucket" and once there, edit / resize pic to medium - save, then copy the IMG code below the pic and past it in your sig.. Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted January 24, 2011 Author Report Share Posted January 24, 2011 anyone know what position the clip should be on for the needle in teen temps.right now i have the clip in the center slot.i for get if i move the needle up it give me more fuel or less Quote Link to comment Share on other sites More sharing options...
banshee 268 Posted January 27, 2011 Author Report Share Posted January 27, 2011 can some one tell me what the float hights should be on 35 pwks.and also the best way to set them Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted January 27, 2011 Report Share Posted January 27, 2011 (edited) can some one tell me what the float hights should be on 35 pwks.and also the best way to set them I believe its 16mm. You tilt the carb on its side to measure from the carb body (where the gasket would go if it had one) and make sure the metal tang is just touching the needle & seat (without compressing it) while measuring to the bottom of the float. http://scootrs.com/tech.cfm?tip=float Edited January 27, 2011 by sprinklerman Quote Link to comment Share on other sites More sharing options...
