That you have an air leak somewhere on the lighter side, a head gasket leak on the lighter side, or that your plug or boot or something else isn't making a spark on the darker side. Just some things that could be wrong.
Thank you! I'll start looking for those.
Dark on one cylinder vs the other? Or, Darker on one side of the plug vs the other side of the same plug?
Darker on one side of the plug. Both plugs look pretty much the same.
Combustion chamber shape, carbon build up, and fuel being used all effect that pattern. It is probably nothing to worry about unless it looks like there is water intrusion in the cylinder.
I dont see a water sings at all. I guess i'll just run it. Thank you for your help.
