stock stator? I have a set of lazer stars rated for the stock stator and there better than stock but nothing like a four stroke. trail tech makes a set like the lazer stars and a set of hids that they say can be run off stock stator with a floating ground but I'm not sure. leds seem like some good stuff but I've never seen a set.
Yeah, stock stator i've been looking at trail tech or piaa extreme white light kit but they seem alittle pricey..
I run Piaa H6M replacement bulbs. They produce a nice bright white light. You can get knock off bullbs on ebay but I run the real deal.
X2. Those are super nice. I haven't bought a set, but seen them and they are ALOT brighter over stock. The tusk brand at rocky mountain atv aren't bad too.
H6M is just the bulb type. Kind of like H3's, 9004's, 9005's, 9007's. There are some blue knock off bulbs on ebay that are much cheaper. I think my Piaa H6M bulbs were around 25-30 bucks each. If they are charging you in that price range make sure they are Genuine Piaa's and not the knock off's. Also dont touch the bulb or the oil from your fingers will cause them to burn out or blow.
I run them because I prefer the stock head light look. I also run them in my 660 raptor. They are a nice bright white.
josh
