chillls Posted January 6, 2011 Report Posted January 6, 2011 thinking about doing a +4 mill kit with dune port for the next mod whats involved in doing this kit? whats the best kit or way to go? & is this set up also considered a 400 kit? would like to be able to use some of the parts i already have im running 34mm carbs 6" K&N pods 4 deg key T-5s cool head changing domes is no big deal & getting an adjustable timing plates is probably the way to go too whats your thoughts on this Quote
Wildcardracing Posted January 6, 2011 Report Posted January 6, 2011 Well, you have a pretty good package of supporting mods to do up a nice stroker dune motor. My advice is to go with a longrod crank and to use cut domes instead of a spacer plate. This will give you the best reliability. I would suggest ditching the timing key in favor of a plate, I've seen the offset keys shear and damage flywheels/crankshafts in the process. The 4mil with stock cylinders will displace between 373cc and 396cc with Wiseco's 795 series pistons available in 64mm-66mm in .020" increments. I would suggest getting the parts from the builder you plan to use for the portwork that way you won't endup buying items you don't need or that don't work the best with his particular setup. If you want you can give me a shout and I can put a package price together for you. Our engines are custom tailored to the rider not just generic "kits". -Brandon Quote
06specialedition Posted January 6, 2011 Report Posted January 6, 2011 Well, you have a pretty good package of supporting mods to do up a nice stroker dune motor. My advice is to go with a longrod crank and to use cut domes instead of a spacer plate. This will give you the best reliability. I would suggest ditching the timing key in favor of a plate, I've seen the offset keys shear and damage flywheels/crankshafts in the process. The 4mil with stock cylinders will displace between 373cc and 396cc with Wiseco's 795 series pistons available in 64mm-66mm in .020" increments. I would suggest getting the parts from the builder you plan to use for the portwork that way you won't endup buying items you don't need or that don't work the best with his particular setup. If you want you can give me a shout and I can put a package price together for you. Our engines are custom tailored to the rider not just generic "kits". -Brandon X2. Hit up Brandon at Wildcard ^, they do top notch work.... and build some awesome running machines! Quote
chillls Posted January 7, 2011 Author Report Posted January 7, 2011 ya i wasnt planning on going with the spacer plate would rather do this right the first time & not have to do it twice what exactly are the difference between the CUBs vs a standard cylinder? bare with me here i dont know a lot about this 4mil but from the small amount ive read & what people have said about it this is the way i want to go i realize im going to have to get.... .new crank .pistons .cylinders .domes .timing plate .? i like the top end power but would also like some lower power to so im thinking this set up is what im looking for what else can you guys tell me about this & what i should consider? Quote
BigRed350x Posted January 7, 2011 Report Posted January 7, 2011 ya i wasnt planning on going with the spacer plate would rather do this right the first time & not have to do it twice what exactly are the difference between the CUBs vs a standard cylinder? bare with me here i dont know a lot about this 4mil but from the small amount ive read & what people have said about it this is the way i want to go i realize im going to have to get.... .new crank .pistons .cylinders .domes .timing plate .? i like the top end power but would also like some lower power to so im thinking this set up is what im looking for what else can you guys tell me about this & what i should consider? Go with a ported stock cylinder over the cub cylinder setup. In the dunes you would be much happier with the ported stock cylinders. Your builder will be able to match your porting to your riding style and needs a lot better than a cub cylinder. The cubs have drag port timings and more of a light-switch powerband. There are guys who will tell you that a cub cylinder works fine in the dunes, but compared to a bike ported for the dunes they suck. There is also a new cylinder out from CP industries called the Serval. Its not a bad setup from what I've read. Its a mono-block aftermarket cylinder with port timings more geared towards dune riding. I've never personally rode one or set one up, so I won't suggest it to you, but from what I've read they are a pretty nifty setup. I suggest going with Kevin at HJR. His number is in my signature. Whatever route you choose, he can take care of your needs. Tell him Jared sent you. Quote
Wildcardracing Posted January 7, 2011 Report Posted January 7, 2011 I agree with Jared that a cub is not likely what you are looking for. I would need a very detailed description of the riding that this bike will see. But, you are probably going to be the most happy with a nice ported stock cylinder or Serval. Quote
chillls Posted January 8, 2011 Author Report Posted January 8, 2011 ive heard you guys mention the SERVAL but no nothing about it Quote
06specialedition Posted January 9, 2011 Report Posted January 9, 2011 ive heard you guys mention the SERVAL but no nothing about it If you do a search you will find a few Serval topics....heres one to read: http://bansheehq.com/forums/index.php?showtopic=135072 Quote
chillls Posted January 10, 2011 Author Report Posted January 10, 2011 If you do a search you will find a few Serval topics....heres one to read: http://bansheehq.com/forums/index.php?showtopic=135072 cool thanks for the info Quote
locogato11283 Posted January 10, 2011 Report Posted January 10, 2011 The Serval is above and beyond any stock cylinder setup. I'd go with a Serval. Quote
