From Wiki-know-it-all...
One of the potential drawbacks of using high concentrations of methanol (and other alcohols like ethanol) in fuel is its corrosivity to some metals, particularly aluminium. Methanol, although a weak acid, attacks the oxide coating that normally protects the aluminium from corrosion:
6 CH3OH + Al2O3 → 2 Al(OCH3)3 + 3 H2O
Hence the whole purging process...
Some more information about why its so wonderful.
Methanol has a high toxicity in humans. If ingested, as little as 10 mL can cause permanent blindness by destruction of the optic nerve and 30 mL is potentially fatal,[9] although a fatal dose is typically 100–125 mL (4 fl oz). Toxic effects take hours to start and effective antidotes can often prevent permanent damage.[9] Because of its similarities to ethanol (the alcohol in beverages), it is difficult to differentiate between the two (such is the case with denatured alcohol).
Methanol is toxic by two mechanisms. Firstly, methanol (whether it enters the body by ingestion, inhalation, or absorption through the skin) can be fatal due to its CNS depressant properties in the same manner as ethanol poisoning. Secondly, in a process of toxication, it is metabolised to formic acid (which is present as the formate ion) via formaldehyde in a process initiated by the enzyme alcohol dehydrogenase in the liver.[10] The reaction to formate proceeds completely, with no detectable formaldehyde remaining.[11] Formate is toxic because it inhibits mitochondrial cytochrome c oxidase, causing the symptoms of hypoxia at the cellular level, and also causing metabolic acidosis among a variety of other metabolic disturbances.[12] Fetal tissue will not tolerate methanol.
If any of this didn't scare you away, then run it. Its great stuff. If it did scare you away, then go with the override. Easy choice.
Look man BIGRED might be steering you away, but heres the deal... Alky is WAY easier than most people think. Will you use a little more of it over gas, Yes. Will I need to jet my bike to run it, Yes. Could my bike be doggie on the low end, yes. (only if you dont get the carbs tuned in).. Hes the straight scoop. Ocne you get it tuned, your bike will make more power, run cooler, last longer, and smell better than it ever have before.. Im a "non purger" we run 20:1 castor 927, and I run the bitch on the hose every pass, and when Im done I push it in the corner, and wait the next race the following month. I dont purge. Some do.. Its up to you... If your scared of alky, dont be. We can get you hooked up in the right dirrection so that you setup is fairly close from the gate.
If your in a position of only being to do one or the other at this time, go for the over-ride. Once your on meth and tuned properly, you wont be able to shift that engine anyway due to the high loads on the trans gears. You'll probably need to upgrade to a lock-up eventually after meth, clutches wont handle the stress...gee...the fun, or is the addiction of HP, just never ends!
Meth makes power earlier, higher torque numbers, and will >>>>>>> carry a "lot" more gear and tire.<<<<<always a good thing...Jim
you also use over twice the amount over gas..... so have a massive tank or ride very little :).
you should purge, maybe its different with a 2stroke, with all that pre mix, but ive seen what it does to 4 strokes ( rusts everything and turns the oil to jelly).
I think ur probably right. Its kinda tough shifting in the dirt now but its not to bad on asphalt, guess its spinning harder.
Thanks for the info guys. Definitely got to get both!!!!!
I would say an overide... my gas bike has put the hurt on a lot of banshees because of that overide...
I dont see why not to just do both? It saves money to run alky, its cheaper then fuel, and coverting the carbs costs next to nothing. I have a used pingel valve if you need one.
