So the lake is frozen solid... but theres no snow to ride my sled. So I figure ill stud these extra tires I have for some lake riding fun... should I use the sharpe top screws? Or snowmobile studs? I would like to still be able to drift and powerslide a little... is there a pattern I should use for inserting them?
I have these kind of studs in my tires WT20ATVJÄÄ(Maxxis Razr2) 250 in each rear and if I remember right 150 in fronts.
http://www.wipertec.fi/atvnastat.php
and they look like these.
front (not mine but I have the same)
http://shop.teamlaine.fi/images/large/etunastarengas.jpg
rear (not mine but I have the same)
http://shop.teamlaine.fi/images/large/takacrossinastarengas.jpg
You can do them by your self if you have the tools.
Hope this helps.
-Pasi S.
Thanks for the info guys. I would like to do some drifting and that stuff, I will have to ride on my driveway for like 20ft then down/up a really steep grass/mud/snow hill.
Pasi, do you need special tools to install those style studs?
Yes you will need some tools to do it. I can´t translate all of it so...
You will need this
http://www.kuinoma.fi/files/Gern_komp..jpg
to use this "stud gun" or what ever you call it LOL!
Before all of this you need to drill good holes for those kind of studs.
...and you need use Loctite 480 glue
I don´t know hard to translate HEH!
-Pasi S.
I like kold kutters. Snowmobile spikes will mess you up BAD if you get caught in the rear wheels, and I mean really bad.
You might just be able to go to your local tire shop and have those other kind put in, there just regular snow tire studs.
I use snowmobile studs in the back 65 each tire, best grip you will get kinda hard to turn tho. I Have never got wrapped up in them, I like to keep my feet on the pegs.
If you are talking about those 20mm long Wipertec studs, then they are not regular snow tire studs. Regular "stud gun"(?) (in most of the cases) can´t accept these studs. They are too long to go through.
-Pasi S.
