sum320 Posted December 28, 2010 Report Posted December 28, 2010 Hey i have a 97 banshee i need to take off the gas tank to clean out all stuff thats in it. I took off the plastics in the front and undid all the bolts that hold it in, but i cant get it out. No matter what way i pull on it, it always seems the frame is the in the way. Is there a bolt i missed? I took out 4, or is there a certain way you have to pull it out? Thanks Quote
Judge1 Posted December 28, 2010 Report Posted December 28, 2010 (edited) The frame is more than likely bent. The U shaped portion that holds the stem and radiator gets bent back easily when the bike is rolled. You can bend it back into shape but it should be gusseted. That is usually what keeps the gas tank from comming out. Edited December 28, 2010 by Judge1 Quote
NYUK Posted December 28, 2010 Report Posted December 28, 2010 put a hammer handle under the back of the tank, and pry it out, it should pop out, bent steering loop or not. Quote
sum320 Posted December 28, 2010 Author Report Posted December 28, 2010 Alright thanks guys i got it Quote
Jereme6655 Posted December 29, 2010 Report Posted December 29, 2010 its a tight fit.......but it will come out....if it wont come out then your bikes got a bent steering neck....BUT it will come out.....gotta pop the back up really hard to get it to come out. Quote
dirtydownunder Posted December 29, 2010 Report Posted December 29, 2010 gota take the gas line off too but yeh, they just dont fall out, its all in the wiggle Quote
