sum320
Everything posted by sum320
  1. Oh alright how do you adjust the slides? Is that those idle adjustment screws? But yeah I know I need to get some silencers so i can throw those pipes on. I know they don't have too much low end but I just need some improvement haha.
  2. Oh well Ive cleaned my carbs multiple times and I'm sure that my pilot isn't clogged. But how do you sync the pwks? Do you need that tool or can you just eyeball it? And i really don't like the stock ones i only have the expansion chambers of aftemarket ones so i can't use them.
  3. Hey guys, i have a low end bog on my banshee. It feels like im in too high of a gear for the speed that im going but im in first. Its not too bad, like as long as i my rpms are high enough when i shift to the next gear it runs great, its only when i slow down and srart going again. But anyway i have 28mm Keihin pwks with 140 main 45 pilot and needle in the middle notch. I have K&N clamp on filters and stock exhaust. My elevation is around 300 ft. I know i have to get a bigger pilot jet, but how much bigger? Thanks
  4. I was thinking about doing that but the one muffler i have is just o.k shape. But from what i can see the other parts are just dirty, i cant see any dings or anytihing like that in them.
  5. Alright I'll try that, but would any old silencers do? or no? And i mostly trails and stuff like that.
  6. When I got my banshee it had graydons on it. But of course it was missing a muffler, so for the time being I put stock pipes on it. But now I'm looking to see if maybe I could get another muffler for them. I tried looking around, but I really couldn't find anything. Is there a different brand similar to them that I could just buy mufflers from and just throw them on? Or would that not work? Also I can put pictures up of them if needed, Thanks.
  7. Alright thanks guys ill give it a shot
  8. Hey so ever since i got my banshee i've had problems with gas coming out the overflow, so i took the carb apart and cleaned it and it stopped. But after riding for awhile i noticed that when i would turn the gas on before even starting it, it would start to slowly leak again. So, i took it back apart cleaned it and it stopped but then later the same thing started happening again. So i thought there might be something in the gas tank so i took that off, pressure washed in the inside and put in fresh gas and thoroughly cleaned both carbs and it stopped completely. Now however its starting to leak again and it seems the more i ride it the worse the leak becomes. Its still only the left carb though. I haven't checked float height yet but thats the next thing i might try. Any ideas?
  9. Alright thanks guys i got it
  10. Hey i have a 97 banshee i need to take off the gas tank to clean out all stuff thats in it. I took off the plastics in the front and undid all the bolts that hold it in, but i cant get it out. No matter what way i pull on it, it always seems the frame is the in the way. Is there a bolt i missed? I took out 4, or is there a certain way you have to pull it out? Thanks
