im new here but iit happend to me my fuel filterin the tank was cloged so it wasnt geting enough gas take the fuel line off and turn the gas on and see if gas comes out and try it on reserve to or it could be a fouled plug or a dirty carb
if the fuel filter is clogged it will probly run for a little then shutoff and take a wile to start back up bc the fuel isnt getting down to the carbs
fould plug it will most likely back fire and keep poping
or a bad reed witch means you wont get any compression in the cylnder and you will feel sair coming out of the intake
try new plugs and clean the filter in the tank it 2 philip screws
