Josh Z Posted December 21, 2010 Report Posted December 21, 2010 I need some help with how the mounts are supposed to look on some oofs I know it mounts on your foot peg but mine is looking kinda weird and they are really close to my tires. post some pics of your mount set ups please! Quote
rdzbangshee Posted December 21, 2010 Report Posted December 21, 2010 no instructions i red neck my stuff all the time o would sen it back for a new pipes they screwed you Quote
Hilarious Posted December 21, 2010 Report Posted December 21, 2010 I need some help with how the mounts are supposed to look on some oofs I know it mounts on your foot peg but mine is looking kinda weird and they are really close to my tires. post some pics of your mount set ups please! Its not uncommon to use a bent piece of flatbar to secure your pipes to your footpeg. Its also a good idea to put a piece of rubber between the pipe mount and peg or flatbar. That will cushion out unwanted vibration and not break the mounts. I suggest a trip to the hardware store. Hope this helps Quote
Blewbyu Posted December 21, 2010 Report Posted December 21, 2010 also if they are some of the new ones out the same side where shearer put spacing in between the two pipe mounts for rubber, they will look like crap and not line up. A few buddys ran into this problem and sold them and bought some of the old style where they mount together rigid. Quote
Josh Z Posted December 22, 2010 Author Report Posted December 22, 2010 also if they are some of the new ones out the same side where shearer put spacing in between the two pipe mounts for rubber, they will look like crap and not line up. A few buddys ran into this problem and sold them and bought some of the old style where they mount together rigid. They are the newer ones, and they do look like crap. The angle is weird so there is a gap where the exhaust ports meet the pipes and they rub on the frame. That sucks! Oh well. Guess I'll jimmy rig it next weekend. Quote
Josh Z Posted December 22, 2010 Author Report Posted December 22, 2010 (edited) http://jzitting.php.cs.dixie.edu/partout/shearer_hanger.JPG I just spaced it out with some washers but it isnt right. Edited December 22, 2010 by Josh Z Quote
tedd1 Posted December 22, 2010 Report Posted December 22, 2010 Make sure the flanges on the pipe are square on the the motor. If they are crooked they will never seal. You may have to raise them up a little at the pegs to keep them off your tires and straight on the motor. Raising them will get them off the frame as well. Quote
sleeper06 Posted December 22, 2010 Report Posted December 22, 2010 mine are low I have a 3/8 steel spacer,but im narrow in the rear so its not an issue,raise em up,I just made a bracket for cpis last weekend took about an hour and some 1/8 inch plate Quote
