Ok just went to sears and got a compression tester http://www.sears.com/shc/s/p_10153_12605_00947089000P?prdNo=9&blockNo=9&blockType=G9 to check compression and both cylinders are at ( 160) with 6 to 7 kicks. The problem is i can only pull start it but when you get it to run and warm up you can kick start it but if you let it sit over night you have to pull it again.. What octane would you run in this thing.
you should be running around 97 octane with that compression. i have the same problem right now with the starting, its because of the temperature drop, your jetting is too lean for the temp. go up a couple sizes in the main jet and it should start fine.
you missing the choke tube?
Ye the choke tube is on. I do have stock carbs, I was thinking just going buying alittle bigger carb good or bad? When i got this thing he said it was just rebuild its got a cool head have no idea what domes, sst exhaust do have a air box but with no lid
