wakullabanshee
1 Follower
    wakulla, Fl
wakullabanshee's Achievements
  1. Do not use the right stuff. I used it on cars in the past, that shit is ment to go on and not come back off
  2. I think the deal is off because hes not wanting to take it to the guy that did all the port work. Hes was asking $1800. O well ill keep looking for another shee. Thanks, James.
  3. heres a couple of pics of it. I didnt ask what year it is.
  4. im going to go back and look at this thing on tuesday.
  5. I wanting to buy another banshee and wanting to know whats a good starting price to start at. Here's aittle of what i know about it. FMF fatty pipes, keihin 28mm carbs. Didn't get to see what reeds he had. Know the things he says that had been done 4 mil stroker with stock bore with new pistons. Shaved head, Ported jugs. Im going to call the guy monday that did all the port work and confirm this. ASV levers clutch and brake. I was going to bring the compression tester with me but forgot. The only thing i didnt like was when i started to ride 3 gear kinda gased it and could not get it to get it in the powerband tryed a couple of time and thought i saw 2 cops so i pulled in his yard and turned it off. Now the bad the chain did break and chiped alittle pieces of the case didnt see any oil around it. And when i was there the bike was cold. When he stated it up the first kick and idle just fine siting there for a couple minutes. 1.whats a good price to start at. 2. whats a good psi on the the cylinders. Im in flordia.
  6. Give me a call 8505444639 James
  7. Ye the choke tube is on. I do have stock carbs, I was thinking just going buying alittle bigger carb good or bad? When i got this thing he said it was just rebuild its got a cool head have no idea what domes, sst exhaust do have a air box but with no lid
  8. I tryed that and nothing.
  9. Ok just went to sears and got a compression tester http://www.sears.com/shc/s/p_10153_12605_00947089000P?prdNo=9&blockNo=9&blockType=G9 to check compression and both cylinders are at ( 160) with 6 to 7 kicks. The problem is i can only pull start it but when you get it to run and warm up you can kick start it but if you let it sit over night you have to pull it again.. What octane would you run in this thing.
  10. One more thing if I let it warm up its fine.
  11. If i try cranking it in gear with clutch in the banshee goes forward but if it in neutral its fine. This is my first banshee so any help would be thankful. Thanks James.
  12. Do you have a flywheel, stator, timing plate.
  13. Give me a call about the flywheel and the stator. 850 544 3197 james.
  14. Do you still have a flywheel and a good working stator. If so give me a call because i dont get on here to much 8505443197 james.
