Hello.
I wonder what position i need to set the rear lowering kit on?
second,third or fourth?reason i ask its because i dont want to stop and adjust this out in the cold while i'm out driving lol.
This is for driving on the ice.
i dont what your running for a set up but you want it to sit level with you on it.if you dont do this you will loose turning grip under power cause you to push in the corner and youll loose alot of speed do to you having to slow down to turn.tell me what set up ur running and i might be able to help you more.this is what mine looks like right now
Thats a nice bike you got there.
Mine is all stock,only got some fmf fattys on it.i went from maxxis with studs over to ching cheng i tink the name was.8" rims back,9 in front.
Now i feel i have to bump my ass a little bit hard down on the seat to get the power down out of the corners.so i thought it would be bether if i put the lowering kit on.
If your having trouble with traction, lower the rear and keep the front higher.
The rear of my bike sits MUCH lower than the front.
Ok.so i dont have to put on the lowering kit infront?
Yes, nether of my bikes have lowering on the front just some decent shocks. the rear dogbone part i think is 7" hole to hold. when i sit on it, it drops alot.
that is what it looks like with nobody on it
With me on it.
With me on it.
Ok thanks for the advice.nice pics.
