Dgrey Posted December 11, 2010 Report Share Posted December 11, 2010 Alright so all my mods are in my signature. I started trying a few different things (main jet and timing) after I burnt up a piston. It was my own fault on the pistons as I was wide open on the flats for far to long. anywys after the rebuild it ran fine for 1 trip out to Glamis. After that (no changes made) the next trip the plugs started backing out and oil was coming out of the head. Called Keving (excellent guy, awesome builder and very helpful by the way) and he suggested I take the timing from +7 to +5. following direction after this trip I put the timing from +7 to +5 (all still running the same 100 octane gas I always have) the bike works perfect for 1 day. The next day i cant hit any hills. The bike starts fine, idles fine, and runs fine, but what it does is just fall on its ass at high rev right at/past the power band. Really feels like the choke is on or its running out of gas or it needs to be cleared out. So at the desert I take both carbs appart and they are perfectly clen. I change the plugs and she fires right up. Hoping the cleaning may have done someting I take it out for a test run and it does the same thing. Oh yeah also checked the timing plate and it was not loose and still on +5 like i put it. Pod filters were also clean and nice. The "old" plugs also looked fine. so... yeah i am stumped. tried to call Kevin (he called back) but our work hours are opposite so we keep missing each other so I thought I would post up here... you guys are always helpful. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 11, 2010 Report Share Posted December 11, 2010 very first thing that comes to mind, is the rs stator got cooked, and making weak spark. i would check that you have good, strong, blue spark, and see what the plugs are telling you. ohm things out (rs has it's own ohms readings, btw) weak spark can present like rich jetting, too. if it ran good with the same conditions and same jetting before, i would start there. also, do a compression test and see if you lost some from the detonation... Quote Link to comment Share on other sites More sharing options...
Dgrey Posted December 11, 2010 Author Report Share Posted December 11, 2010 very first thing that comes to mind, is the rs stator got cooked, and making weak spark. i would check that you have good, strong, blue spark, and see what the plugs are telling you. ohm things out (rs has it's own ohms readings, btw) weak spark can present like rich jetting, too. if it ran good with the same conditions and same jetting before, i would start there. also, do a compression test and see if you lost some from the detonation... yeah actually had to send 1 RS Stator back and the next one I got was legit. Had it on there for about 2 years now.... I know and have the tool to check compression, but how do I check to see if there is a "good, stong, blue spark?" Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 11, 2010 Report Share Posted December 11, 2010 Pull plugs , put them back into boots , lay them on top of head , kick it over . It should be "electric" blue not some lame ass yellowish color. Quote Link to comment Share on other sites More sharing options...
BigDoug Posted December 11, 2010 Report Share Posted December 11, 2010 I have the EXACT same problem on a motor i just put together, this motor also has a ricky stator... before I look very far, i am going to replace it with a stock stator. The motor idols perfect and sounds great, you can ride it around perfect at low rpm's right up to were the powerband hits and the revs shoot up... it's very consistant on were it breaks up. let me know if you find out anything, and i will do the same. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 12, 2010 Report Share Posted December 12, 2010 I have the EXACT same problem on a motor i just put together, this motor also has a ricky stator... before I look very far, i am going to replace it with a stock stator. The motor idols perfect and sounds great, you can ride it around perfect at low rpm's right up to were the powerband hits and the revs shoot up... it's very consistant on were it breaks up. let me know if you find out anything, and i will do the same. it's not always the rs. there are several out there running good, but the story-line points to it as one of the most likely scenarios...check the jetting, and if it's rpm specific, look into your plug caps. does it clean out after, or with different throttle? Quote Link to comment Share on other sites More sharing options...
BigDoug Posted December 12, 2010 Report Share Posted December 12, 2010 it's not always the rs. there are several out there running good, but the story-line points to it as one of the most likely scenarios...check the jetting, and if it's rpm specific, look into your plug caps. does it clean out after, or with different throttle? There is no clean out, and i replaced the coil (checked caps)... seems to be very consistant. replacing everything electrical with stock parts... wiring looked like a mess to me so it will all be replaced, better to start fresh. Quote Link to comment Share on other sites More sharing options...
cjc Posted December 13, 2010 Report Share Posted December 13, 2010 you can also close up the gap on the plugs some,if the system is weak,it will take some load off it. Quote Link to comment Share on other sites More sharing options...
06specialedition Posted December 13, 2010 Report Share Posted December 13, 2010 The bike starts fine, idles fine, and runs fine, but what it does is just fall on its ass at high rev right at/past the power band. Really feels like the choke is on or its running out of gas or it needs to be cleared out. Are you running a pingle valve? Just a shot in the dark but.....Maybe your sucking your bowls dry?!? Quote Link to comment Share on other sites More sharing options...
fastquad02blaster Posted December 15, 2010 Report Share Posted December 15, 2010 Sounds electrical to me too. I would put my money on the stator. Not saying RS is junk, just saying bad stator. Quote Link to comment Share on other sites More sharing options...
KEVSWS6 Posted December 15, 2010 Report Share Posted December 15, 2010 Try to gap the plugs at .22 and make sure the flywheel pickup is at .18 It will most likely be the RS stator. Get a stock one on it. Quote Link to comment Share on other sites More sharing options...
BigDoug Posted December 16, 2010 Report Share Posted December 16, 2010 Replaced wiring harness and replaced RS stator with stock one... Runs great! Quote Link to comment Share on other sites More sharing options...
AKheathen Posted December 17, 2010 Report Share Posted December 17, 2010 Quote Link to comment Share on other sites More sharing options...
06specialedition Posted December 17, 2010 Report Share Posted December 17, 2010 Replaced wiring harness and replaced RS stator with stock one... Runs great! Hell yeah.... Quote Link to comment Share on other sites More sharing options...
dcalsv02 Posted December 19, 2010 Report Share Posted December 19, 2010 Check the coil. I had that same problem and it ended up being the coil. Quote Link to comment Share on other sites More sharing options...
