juiceboxxx26 Posted December 6, 2010 Report Posted December 6, 2010 I have a few problems with my new shee. Just built her and now finally got it running and when it starts up it idles very high and is unresponsive to the tors scres to adjust the idle i have the jets at 25 pilots 2 turns out on the air screw and 270 mains has full stock exhaust k n n air filter at sea level and that was with the air filter lid off when idling i am not getting strong exhaust out of the tailpipes the left carb was dumping fuel and then when i adjusted the float in the right side now the other side dumps fuel. Please help me out what would cause the bike to idle high and hang when i rev it up? Quote
wacko2000 Posted December 22, 2010 Report Posted December 22, 2010 Air leak, Lean condition, slides in backwards... What do you mean when you say, just built her?? Is the motor fresh or you just assembled the bike? Quote
oneill_1952 Posted February 6, 2011 Report Posted February 6, 2011 Sounds like your carbs are out of sync, could be caused from a kinked throttle cable, one slide is definalty hanging. Quote
bansheesrtoys Posted February 6, 2011 Report Posted February 6, 2011 did you put the choke tube back in that goes from carb to carb? Quote
