miami350 Posted December 1, 2010 Report Posted December 1, 2010 im having some problem with my rear brakes they would only hold up pressure for like 4 days then it get soft so i bleed them again and it does the same for 4 days What can be wrong?????.... i dont see no oil leak !!! Quote
jbooker82 Posted December 1, 2010 Report Posted December 1, 2010 Do you have the rubber diaphragm in the reservoir Quote
Larry's Shee Posted December 2, 2010 Report Posted December 2, 2010 Might be master cyl taking a dump Time for re-build kit. Quote
AKheathen Posted December 2, 2010 Report Posted December 2, 2010 you sure the caliper is not damp? try cleaning everything with brake cleaner after bleeding... Quote
miami350 Posted December 3, 2010 Author Report Posted December 3, 2010 yea its has the rubber diaphragm ... and also i took all the old oil out and but some new one in Quote
AKheathen Posted December 3, 2010 Report Posted December 3, 2010 do they get soft after sitting, or gradually as you ride? did you just replace the pads? how is the rod adjustment? Quote
miami350 Posted December 3, 2010 Author Report Posted December 3, 2010 do they get soft after sitting, or gradually as you ride? did you just replace the pads? how is the rod adjustment? yup after sitting also io just put new pads Quote
AKheathen Posted December 3, 2010 Report Posted December 3, 2010 i would suspect a seal in the caliper, if it happened after changing the pads. also, make sure the pedal isn't adjusted out too far, keeping it from leaving the reservoir orifice open normally. good way to tell is by pushing the pad in and see if it pushes fluid back into the reservoir easily. not real likely the prob, but possible... Quote
