Okay I'm going to see what we can do about my banshee not starting.. First off its 4mil, Ported, 34mm PJs, toomey t5, vforce 3, prodesign intake, plus other stuff to frame and Body.
Anyways I am needing just a little help. I finally broke down and bought a cool head. So I took my running banshee apart today. It was running great before I started this. So I put the cool head on with 20cc domes. put everyting back together and motor wont start.
I have fire from spark plugs...
I have compression, new cool head.
I am getting fuel plugs are wet when i pull them to check them.
Banshee will not start. I sprayed starting fluid and it ran for 1-2 seconds. Any thoughts?
if it starts with starting fuel the problem is more then likly in your carbs if its been sitting for awhile check your floats. if it just happend out of nowhere check your fuel lines see if there is fuel going down.
well if it was running before you took the head off. maybe your orings got cought and you got water in your system.
It ended up being the rubber grommets on the intake boost bottle. They pushed up inside the boost bottle when I reinstalled it.
I'm running a 48 pilot jet 172 main and needle on 2 clip from top. I live in KY so I don't know my elevation. But thats what runs with mine and seems like it is hitting right on all parts of throttle.
