bansheex666 Posted November 24, 2010 Report Posted November 24, 2010 Rebuilt the carbs, Now it's bogging down low. Never did before, how do u fix this? I messed with the air fuel screws on the carbs but I can only get it so close. Any other adjustments I'm missing? Quote
06specialedition Posted November 24, 2010 Report Posted November 24, 2010 Rebuilt the carbs, Now it's bogging down low. Never did before, how do u fix this? I messed with the air fuel screws on the carbs but I can only get it so close. Any other adjustments I'm missing? What pilots are you running? Quote
12 0 Clock P I M P Posted November 25, 2010 Report Posted November 25, 2010 do you have tors? make sure your in sync...maybe one slide is opening early/late choking out one side....... Quote
bansheex666 Posted November 30, 2010 Author Report Posted November 30, 2010 Im running 25 pilots. Same size as I was before. Mains where not changed. Syncin them could really be the b Problem? I mean I cannot get it to run right no matter what. Quote
rdzbangshee Posted December 1, 2010 Report Posted December 1, 2010 i was told to take off the head every 20 hours for inspection i cant go for more than 60hrs tell it melts the rings and locks up Quote
