bansheex666
Everything posted by bansheex666
  1. I have 8 wheels I want to trade for four, and a blue and black seat for a black or black and white or black and silver seat. I'm looking to trade all these wheels for 21 fronts and 20 rears on rims. Need good tread must hold air. Two of these with 18x10x8 holeshots. Brand new! Two of these front rims with stock front tires And these four. Fronts are same style as the 8 inch rims with 23 inch holeshots and rears are stock rims with 22 inch holeshots. all four treads in good shape. Here you can also see the seat I need to trade
  2. I have 22x11x9 hole shots on rims. I need 22x11x8. Do not need rims. I know it's a weird size but I'd give it a shot. Either that or if anyone has the Beadlock looking wheels, the fake ones in 9 inch. Cause I have 8 inch ones.
  3. Itp, the directional ones, trade for 22s or 23s. They're 20s
  4. Im running 25 pilots. Same size as I was before. Mains where not changed. Syncin them could really be the b Problem? I mean I cannot get it to run right no matter what.
  5. Rebuilt the carbs, Now it's bogging down low. Never did before, how do u fix this? I messed with the air fuel screws on the carbs but I can only get it so close. Any other adjustments I'm missing?
  6. Ok got everything running at 95%. It just bogs on low end. I can tune the carbs so they don't do that?
  7. Also replaced the plugs again today. Twice.
  8. I meant pullstarting like someone pullin me. And yes the tube is on. Today with the help or starting fluid we got it started. But the right side wasn't running and I couldn't get it to idle with out the choke out, and then after some more attempts the right side would run then Both for a second, then only the right would run, I just couldnt get it running right or stay running at all. It won't start with out the fluid, and it wont right at all. Any ideas?
  9. Just did a top end rebuild, and when we did that we decided to do the carbs. Ling story short now it doesn't run. I cant kickstart it, so we tried pullstarting it, and it sounds like it gets a little gas, runs for a second then dies. The plugs were getting soaked in gas. It had spark, I just don't know what to look for
  10. How soon could you ship them out?
  11. I might be interested in that. Pretty much what I'm looking for.
  12. Need different fronts. I want more of an mx tire on a stock or similar front to . Open to anything.
  13. I'm having an issue viewing the PMs on my phone bansheeman email me at [email protected]
  14. That's the best I have currently for pictures.
  15. Hi, I really need a rear hub, and I'm willing to trade a full set of motorsports nerf bars with black nets. Good condition. I will also trade a set of moose racing bars, if your not interested in the nerfs. Also looking for a headlight switch, and rear tires. Message me asap! Thanks. **The bars are silver, but I can have them anodized any color you'd like.
  16. Pm me either way, I need at least one hub asap.
  17. Would you trade one rear hub for a full set of motorsports nerf bars? If not I'll just buy the hubs.
  18. Def interested. Your not willing to seperate are you?
  19. thanks for the axle write up, and after a while no matter what it still leaks a little. ill hafta take it apart and see
  20. I might be able to nickel plate them for you, that's pretty close to chrome, it's accually one of te steps. It all depends on the surface of the pipes
  21. I have two problems. one, after a little while riding my quad heats up and coolant leaks on my right pipe. and if i put coolasnt in the overflow it pors out almost immediatly. it also pours out of i stand it on its ass. im guessing thats a bad resevoir line? the other thing is I have a blown rear bearing. how hard is it to replace? like tkaing the axle out and whatnot. thanks in advance!
  22. Trade for bills pipes? I'll even throw in some rear holeshots.
  23. What are you looking for? I have itp rims with brand new holeshots. And back stock rims with holeshots
  24. I do 32:1 I heard was optimal.
