Hi everyone, im trying to find a write up on whats needed to convert a motor to alky but cant find anything.
I already have the carbs but I need to know what do I need to do to the engine. For example
- I have 170psi right now, what psi should i be running?
- where do i set my squish/clearance?
- what type of timing do alky motors run?
- do i still run b8es? do i gap it to a different number?
Its a 421cc cub used for 1/4 mile asphalt dragging.
Am i missing anything else?
180-185 compression.
br9es plugs gapped at .018
different motor setups like different timing. +6-+12 i run +10
running the 1/4 i would stay safe on the timing due to heat. say around +7
Most important thing is to start way rich and work your way down. The first pass down the track on a new setup I like it to spew alky all the way down the track. You may not want to run a full 1/4th mile like that, as you'll probably run the bowls dry. I assume you have a dual pingel, gutted gas cap, and billet bowls. Suggestions above are a good starting point on timing, etc.
