gizmoman Posted November 20, 2010 Report Posted November 20, 2010 Fuel leaks from the bottom of my carbs through the tube that runs down and it doesnt stop unless i turn my gas off and its really bad after i first shut it down after riding what could be causing this? Quote
shadowbanshee Posted November 20, 2010 Report Posted November 20, 2010 that sounds like your floats are stuck or need adjusted. try tapping lightly on the side of the bowl with the butt of a screwdriver, and see if that helps. if not its probably your height like stated before. Quote
12 0 Clock P I M P Posted November 20, 2010 Report Posted November 20, 2010 should get in the babit of turning your fuel off anyway..... Quote
