itscody Posted November 2, 2010 Report Posted November 2, 2010 I want to paint a few things on my bike. Whats the best kind of paint to use to paint the exhaust? And the swing arm & a arms? I'll be using a air compressor spray gun. Quote
itscody Posted November 3, 2010 Author Report Posted November 3, 2010 I want to paint a few things on my bike. Whats the best kind of paint to use to paint the exhaust? And the swing arm & a arms? I'll be using a air compressor spray gun. No suggestions? Quote
VooDooBanshee Posted November 3, 2010 Report Posted November 3, 2010 I know a lot of guys use the VHT paint and use the baking process in an oven between coats. I have used the high temp paint on pipes and it worked awesome. It's a rattle can, but for pipes they turn out good. Quote
itscody Posted November 3, 2010 Author Report Posted November 3, 2010 I know a lot of guys use the VHT paint and use the baking process in an oven between coats. I have used the high temp paint on pipes and it worked awesome. It's a rattle can, but for pipes they turn out good. Thank you and can i pick up some high temp paint at the auto store or is there somewhere speical i got to get it? and as far as the baking process i dont really have those resources. So what else could i do to paint the a-arms and swingarm? Quote
itscody Posted November 3, 2010 Author Report Posted November 3, 2010 for baking, you can always just start the quad and let it run for like 20 minutes. also it is more the prep work you should be worried about. that will make the difference. As far as bakin this way. What do I need to do. And what kind of paint would I use. Quote
itscody Posted November 3, 2010 Author Report Posted November 3, 2010 um just some header paint. you can get it at an auto paint store. Okay. And once I paint turn bike on for like 20 mins once knowing exhaust? And what's good to use to paint a arms and swing arm. Quote
