dicedealer702 Posted October 29, 2010 Report Posted October 29, 2010 i want to remove the spring off my yfz450 shock to have it p.c. i am sure i will need a spring compressor but what do i do after i compress the spring? what would be the best way to put it back on? thanks Quote
Snopczynski Posted October 29, 2010 Report Posted October 29, 2010 i want to remove the spring off my yfz450 shock to have it p.c. i am sure i will need a spring compressor but what do i do after i compress the spring? what would be the best way to put it back on? thanks Front or rear? Quote
dicedealer702 Posted October 29, 2010 Author Report Posted October 29, 2010 Front or rear? FRONT Quote
-Herbie- Posted October 29, 2010 Report Posted October 29, 2010 I bought these from harbor freight and used them to get my yfz450 springs off. I just ratchet strapped each of them across from each other to the end of the shock with the reservior and slipped the single prong side into the spring then wrenched it down until i could pull the retainer clip out. I trimmed an 1/8" off the single prongs andwrapped them with electrical tape so they would not scratch the springs. Its kind of a pain to work with these but it worked for $10. http://www.harborfreight.com/macpherson-strut-spring-compressor-set-3980.html Quote
So Cal Suspension Posted October 29, 2010 Report Posted October 29, 2010 Snop, what happened to your spring compressor that you made? Quote
Snopczynski Posted October 30, 2010 Report Posted October 30, 2010 I still have the compressor. You dont need a compressor for front yfz450 springs (at least the ones I have). You just unscrew the nuts all the way and push the spring down a little then pull the collar out. Quote
