hey guys so im going to the desert tomorow and would like some help... i ran my bike today ran good besides coolant is comming out of the overflow too much of it. i have a billet water pump in it however my radiator isnt in the ebst conditiion the fins are about 70 percent bent :( i opened the raditator top and the coolant was white foam at the top im using engine ice. thanks fellas!
start with a fin comb, and check/replace the radiator cap. fill it up with the cap off and start it. it should be flowing some, and maybe a couple bubbles on start-up, but they should go away and not be bubbling, or continually pushing coolant out. also, if the coolant rezivoir is hooked up back-wards, it will dump the coolant out and suck air in.
