If you go back and forth from shock to strut, leave the link or get a no link swinger.
If you only run a strut, you can remove the link and go directly to the swinger.
The shock angle is just too great on link swinger without a link but it makes no difference with a strut.
Rick
strut to swing arm will work fine
Absolutely..
Just make sure to check the bolts often and/or install some grade 8 bolts. I have had both the top and bottom bolt that runs through the strut break (at different times). They only looked slightly bent, but the bottom one was cracked halfway and the top broke in two (at a later time) - I went to loosen it and I just pulled half the bolt right out of the strut; then the other half out of the other side of the strut. . Kinda scary; I'd just made a pass on it.
