Gikki44 Posted October 10, 2010 Report Posted October 10, 2010 The manual is calling for a 16:1 premix for break in. Is this what should be used or not? And it also calls for straight 10w30 engine oil? What is everyone using? Quote
ECshee Posted October 11, 2010 Report Posted October 11, 2010 32:1 always. and hond pro trans oil Quote
James-26 Posted October 11, 2010 Report Posted October 11, 2010 Just run the same mix your going to run when then engine is broke in. Quote
stacman450 Posted October 11, 2010 Report Posted October 11, 2010 Just run the same mix your going to run when then engine is broke in. x2 Quote
Gikki44 Posted October 11, 2010 Author Report Posted October 11, 2010 Alright, sounds good. Any recomendations for the break in. As far as the first start up and run? Quote
06specialedition Posted October 11, 2010 Report Posted October 11, 2010 Alright, sounds good. Any recomendations for the break in. As far as the first start up and run? Make sure its warmed up...then ride it like you stole it Quote
KickStartMyHeart Posted October 11, 2010 Report Posted October 11, 2010 Alright, sounds good. Any recomendations for the break in. As far as the first start up and run? Ive done both the "break in heat cycles" and the ride it like your gonna ride it break ins. With the heat cycles I could never get the rings to set and the compression was always low. Ive done that method twice and both times didnt work. The other times, I let it warm up and ride the damn thing like Im gonna ride it aka HARD. Never have had any problems wit the ride it like u stole it method. But u do what makes u feel the best. I mix my fuel at 36:1, but stick with a 32:1 and u wont have any problems. Its all up to you how you break in ur engine. Quote
AKheathen Posted October 12, 2010 Report Posted October 12, 2010 you are going to need to re-torque the head after a few heat cycles, but the worst thing you can do is baby it and over-oil it. free-running just dulls the rings, because there is very little pressure behind the rings to make them cut. Quote
Gikki44 Posted October 12, 2010 Author Report Posted October 12, 2010 All sounds good. Yea i've been building cars, mostly imports with forced induction, for a pretty long time. There's always the arguement of the break in! More likely than not depending on the build i'll always give it some good juice on the first run. I think it helps to seat the rings much better. Always thought the same thing, if youre gonna treat it like a baby its gonna drive like a baby. Thanks for all the info guys. Cant wait to get all the parts and get rippin again!! Quote
