#1JUANstunna Posted October 9, 2010 Report Share Posted October 9, 2010 PM Sent Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted October 9, 2010 Report Share Posted October 9, 2010 Payment sent for water pump, timing plate, and stator. Quote Link to comment Share on other sites More sharing options...
91tsiawd Posted October 13, 2010 Author Report Share Posted October 13, 2010 Updated List to show parts remaining and lowered prices Parts located in Danville, Pa, but I am willing to meet buyers in the Philadelphia area if buying something over $100 1) Clutch Basket in excellent shape with Boss and Pressure Plate $45 Each Modified Shift Shaft By FAST $25 1) Flowdesign Billet Waterpump Impeller $45 each modded Shift star $15 Fast UPP Chain Slider $15 Black 2) NOSS Billet Heads without Domes (Aluminum in color) $125 each 2001 Seat Factory blue and black cover (no tears) $35 Polished Dogbone $25 2000 Clutch Cover $30 Blue Plastics with cut front fenders $70 Frame Powdercoated (3stages, Chrome Base coat, Red Starlight Top Coat, Then Clear Coat, Frame has been lightened, and strengthed with aftermarket gusset kit Comes with Bill of Origin from dealer (NJ Bike) $300 2) 2001 OEM Stock Coils $35 each Stock Gas Tank $15 2) OEM CDI unit 2001 $55 each 2) Complete Transmission gears with forks $100 each (both transmissions shifted great)Both transmissions out of a 2001 Banshee 2) Stock Steering Stem $35 each 2) sets of 2006 YFZ 450 Shocks $175 per set YFZ 450 Front Hubs $55 YFZ 450 Front Spindles $55 YFZ A Arms cut and with Spacers to bolt on to Banshee $185 2 additional sets of YFZ A Arms without spacers (need to be cut for Banshee use) $145 per set 2 sets) Stock carbs Tors eliminator/cable (various jets) $85 per set Gutted wiring harness with Kill Switch, dirt bike push button kill switch, grounds, and CDI relocation kit (metal bracket that fits behind the radiator) $85 (Does not allow for key, tors wiring, lights, or anything else that is not needed to run the bike) Pile of Sunset sprockets (all are still in great shape, some have less than 2 hrs)$35 Front - 13, 14 Rear - 40, 41, 42, 44 rear Skid Plate $25 (this has been used quite a bit) Aluminum Nerf Bars with pegs (powder coated wrinkle Black with blue nets) $110 New AC Racing Aluminum rear Grab bar Powder Coated Black $55 Direct Drive Polished Lock Out Clutch cover/Lock out (clear lexan plate) $300 Brand New in box DynaTek CDI (Programable) for 97-06 Banshee. You can use this to increase timing and even setup a 2 step rev limiter (requires a Switched clutch lever which can be purchases from Pingel). $185 Alpine Star tech 7 boots size 9 $60 Thor Pants $20 size 32 Thor Shirt $15 Size Large Thor Helmet some scratches $35 Additional Parts will be added this week. Quote Link to comment Share on other sites More sharing options...
bounty banshee Posted October 17, 2010 Report Share Posted October 17, 2010 I'm starting a new ad, since my last ad became very difficult to see what is still for sale. PLEASE PM ME WITH QUESTIONS OR IF YOU ARE INTERESTED IN PARTS. I want to keep this ad clean so others can easily see what is available. All Parts are listed without Shipping fees. Parts located in Danville, Pa, but I am willing to meet buyers in the Philadelphia area if buying something over $100 Billet Dip Stick $15 Modified Shift Shaft By FAST $25 2) Flowdesign Billet Waterpump Impeller $45 each V Force 3 Reeds $100 Needs 1 new Pedal kit from Fast (cost on their site is $60 for replacement pedals) Fast modded Shift star $15 Adjustable Timing Plate $25 Clutch Pancake Bearing $20 Fast UPP Chain Slider $15 Black 2) NOSS Billet Heads without Domes (Aluminum in color) $125 each 2001 Seat Factory blue and black cover (no tears) $35 2001 Stator OEM Not aftermarket $60 Clutch Pack (Springs, Plates, Fibers (Clutch material is the FAST kit) $35 Polished Dogbone $25 2000 Clutch Cover $30 Blue Plastics with cut front fenders $70 Frame Powdercoated (3stages, Chrome Base coat, Red Starlight Top Coat, Then Clear Coat, Frame has been lightened, and strengthed with aftermarket gusset kit Comes with Bill of Origin from dealer (NJ Bike) $300 2) 2001 OEM Stock Coils $35 each Stock Gas Tank $15 2) OEM CDI unit 2001 $80 each 2) Complete Transmission gears with forks $110 each (both transmissions shifted great) 2) Stock Steering Stem $35 each 2) sets of 2006 YFZ 450 Shocks $180 per set YFZ 450 Front Hubs $65 YFZ 450 Front Spindles $65 YFZ A Arms cut and with Spacers to bolt on to Banshee $200 2 additional sets of YFZ A Arms without spacers (need to be cut for Banshee use) $145 per set Rear brake with block off, and disc $20 2 sets) Stock carbs Tors eliminator/cable (various jets) $100 per set Gutted wiring harness with Kill Switch, dirt bike push button kill switch, grounds, and CDI relocation kit $100 (Does not allow for key, tors wiring, lights, or anything else that is not needed to run the bike) Pile of Sunset sprockets (all are still in great shape, some have less than 2 hrs)$35 Front - 13, 14 Rear - 40, 41, 42, 44 Aftermarket Clutch Lever/stock cable got this through FAST $25 rear Skid Plate $25 (this has been used quite a bit) Aluminum Nerf Bars with pegs (powder coated wrinkle Black with blue nets) $130 New AC Racing Aluminum front bumper Powder Coated Black $65 New AC Racing Aluminum rear Grab bar Powder Coated Black $55 Direct Drive Polished Lock Out Clutch cover/Lock out (clear lexan plate) $320 Brand New in box DynaTek CDI (Programable) for 97-06 Banshee. You can use this to increase timing and even setup a 2 step rev limiter (requires a Switched clutch lever which can be purchases from Pingel). $200 Alpine Star tech 7 boots size 9 $65 Thor Pants $25 size 32 Thor Shirt $20 Size Large Thor Helmet some scratches $45 Additional Parts will be added this week. Quote Link to comment Share on other sites More sharing options...
eric b Posted October 17, 2010 Report Share Posted October 17, 2010 Send me a email on the sprockets. Price and steel or aluminum in kind? Shipped to 70341 Ericbarbier59@yahoo.com. Thanks Quote Link to comment Share on other sites More sharing options...
YamahaBanshee69 Posted October 17, 2010 Report Share Posted October 17, 2010 how much for the gforce axle shiped to canada thank you Quote Link to comment Share on other sites More sharing options...
SandmanPNW Posted October 18, 2010 Report Share Posted October 18, 2010 Did I see part of a chrome stock grab bar in those pics and is it for sale? PM me if it is and a pic. Thanks Quote Link to comment Share on other sites More sharing options...
91tsiawd Posted October 19, 2010 Author Report Share Posted October 19, 2010 Guys sorry for the delayed response. I did not have access to the internet this weekend and im currently away for work. I willpm everyone with a response and pictures if requested when I get home this weekend. Sorry for the delay on sales but some things came up at work. Quote Link to comment Share on other sites More sharing options...
91tsiawd Posted October 24, 2010 Author Report Share Posted October 24, 2010 All PMs have been answered. Sale is back on, sorry for the delay Quote Link to comment Share on other sites More sharing options...
sheezretarded Posted October 26, 2010 Report Share Posted October 26, 2010 is the frame and the 450 front end still available..... ??? Quote Link to comment Share on other sites More sharing options...
badassbanshee479 Posted October 26, 2010 Report Share Posted October 26, 2010 are you pretty firm on the price for the 450 arms without bushings? Quote Link to comment Share on other sites More sharing options...
eric b Posted October 26, 2010 Report Share Posted October 26, 2010 Paypal will be sent tonight for sprockets. Thanks Quote Link to comment Share on other sites More sharing options...
