Looking to buy a 421 cub kit, what else will i need besides the cylinders and crank?? talked to couple builders they said 421 is good for what i ride (open fast trails and hillshooting)
but im clueless as to what else i would need to go along with the kit and porting. HELP
wouldnt you be better to ask your builder ? there are so many variables in your set up...
Well i thought i could ask here to keep out of his hair a little...im just looking for a little help and trust me ive bugged him enough in last 3 days
you would also need a heavy duty clutch kit as well, maybe even a lock up. a good set of pipes and some bigger carbs too. 421's are strong little motors. imho....i wouldnt run a 421 in the woods, a set of nicely ported stockers will do the trick just fine with a 4mil crank.
well the riding i do around the house is out in a open field, no tight turns or trails whatsoever. alot of space to open it up, thats why he said it would be okay to go with the 421. and i drag it on the side as well and want to be as competitive as i can
It all depends on how much money you want to spend,when you move up to the 421 and up,the v-force 3 reeds work good,by them for anything smaller and its a waste of money because your not pushing enough hp to be effective,a adjustable stator plate is a good investment,unless you run a cdi with adustable timing curve,then a plate is not needed,but some builders do use both of them for methenol,alky and race gas,so what you want to spend and how you want to set it up,but a lockup clutch you'll need,if your running a 7 plate basket,i run a 8plate hinson and they told me I'll need one,but I havent burned them up yet,Look at my mods and thats the limit,unless you want to get into straight drag racing.
A LOT OF MONEY!!! Oh did I mention a lot of money, yeah ur gonna need that. Cylinder $850, Pistons $250, Crank $450, TZ bearings $100, Domes $70, Coolhead $150, Portwork, $350-400, Stud xtenders and plugs $35, Wristpin bearings $25, Oring kit $25, Labor...Who the fuck knows how much thatll cost you. U having second thoughts yet???? Took me a long time to get to a 421 and thousands of dollars later, here I sit happy. Ooooooh, I almost forgot, PIPES.....$400-600.
+6 swinger or longer, pingle valve and a tether kill switch. ( just in case you wipe out )
+6 swinger 350, carrier $100-150, Pingel $100, Killswitch $50. U having second thoughts yet?????? Start a piggybank and just start chunkin money in it LOL
Well if that all seems overwhelming you can cut off the porting because Cub's don't really need porting to run awesome. And you can run one on pump gas so race fuel or alcohol isn't necessary.
I agree and I disagree wit that statement. It doesnt take much to clean up the casting. Why wouldnt ya do it if U already got the cylinder off??
