Think of the reeds as the intake valves on a 4 stroke. With a few changes in port design, they allow for a greater intake flow over a piston port intake design. A reed motor is simply an improvement on a piston port 2 stroke. Piston port 2 strokes are still used where higher RPMs are desired that are not possible with reed motors due to reed float and flutter (like valve float on a 4 stroke) The only mod you can do with the reed valve is to increase flow i.e. fiber reeds, port cages, V Force.
Okay thanks a lot that makes sense! It's pretty much so that when the piston starts coming back up it doesn't push out any of the intake air?
Edit: okay well I had it partially right... lol
Edited by sootman73
