ok fellas so i have a rebuilt motor out of the base of the cylinder on the left side it is leaking oil. theres a new gasket in there and al the bolts are torqued down to the correct specs. what is my problem? bad gasket? thanks guys!
Where exactly is it leaking?
Take a CLEAR up close pic with the macro button pushed.
its leaking right in between the cylinder and cases where they connect
Stop!! Do not run it any more like this.
Did you re torque the cyl and head nuts a couple times after it was run for a lil bit?
They will loosen up a bit sometimes after it's apart and need to be re torqued a couple times till everything settles in.
Go re tighten them to see if they were loose and check back in here with whats up then we'll go from there.
sorry i wasnt on last nigth chris. yeah they are re torqued. it seems like a bad gasket maybe. :( when its on it doesnt leak but about 5 minutes after it will start to leak
