punkass1323 Posted August 21, 2010 Report Posted August 21, 2010 well when i would pull my clutch in there is tension but nothing would engage so i got a new cable still notta then i bought a clutch kit put it in still nothing so i took some pics and need some help also i marked on the basket where there is some wear i think i might need a new one but not sure help please i wanna ride but damn Quote
punkass1323 Posted August 21, 2010 Author Report Posted August 21, 2010 well when i would pull my clutch in there is tension but nothing would engage so i got a new cable still notta then i bought a clutch kit put it in still nothing so i took some pics and need some help also i marked on the basket where there is some wear i think i might need a new one but not sure help please i wanna ride but damn Quote
punkass1323 Posted August 21, 2010 Author Report Posted August 21, 2010 sorry dont know why i cant load all pics at once Quote
toytech Posted August 21, 2010 Report Posted August 21, 2010 does the clutch not release or not enguage? if not enguaging take the springs back off and turn the pressure plate in the basket to a different position it will only fit in the correct spot Quote
punkass1323 Posted August 21, 2010 Author Report Posted August 21, 2010 does the clutch not release or not enguage? if not enguaging take the springs back off and turn the pressure plate in the basket to a different position it will only fit in the correct spot well when i had the clutch in i pulled it in and the pressure plate would move but didnt seem like it was doing the job now there is a sertain way to put the plates in right cause i see theres a hump on each one do those need to be lined up with eachother or what i think im in over my head lol if u have pics or anything please do share thats how i learn the best Quote
Larry's Shee Posted August 21, 2010 Report Posted August 21, 2010 (edited) First steel plate aligns with arrow on clutch boss . Stagger plate 60* clockwise with each successive plate , per Clymers manual. Thumbnail explination , hope this helps. Edited August 21, 2010 by Larry's Shee Quote
bbcmudtruck Posted August 21, 2010 Report Posted August 21, 2010 Are you setting your adjustment screw correctly? That center screw with a nut on it is the one I'm talking about. Back that nut off and use a phillips head screwdriver and turn it in a little bit. Pull your clutch in and see it that helps. Before you button everything up, make sure your arrows on the case and the clutch puller line up. If you have a clymers it should have pictures and explain the process step by step. Quote
punkass1323 Posted August 21, 2010 Author Report Posted August 21, 2010 thank you all for the help i have a repair pro service and owners manual on disc im gunna get this shit going i hope thank you all again Quote
