Mjv420 Posted August 15, 2010 Report Share Posted August 15, 2010 Ive got a bunch of stock parts that need to go, if your needing something just shoot me a reply and we'll work something out. Mike Quote Link to comment Share on other sites More sharing options...
itchy Posted August 15, 2010 Report Share Posted August 15, 2010 Do you have a stator? If so how much? Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted August 15, 2010 Author Report Share Posted August 15, 2010 No stators. Quote Link to comment Share on other sites More sharing options...
banshee332 Posted August 15, 2010 Report Share Posted August 15, 2010 No stators. exhaust springs? Quote Link to comment Share on other sites More sharing options...
eric b Posted August 15, 2010 Report Share Posted August 15, 2010 exhaust springs? clutch side,, do you have all the gears and stuff on that side? .....let me know Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted August 15, 2010 Author Report Share Posted August 15, 2010 exhaust springs? I will check and get back with you clutch side,, do you have all the gears and stuff on that side? .....let me know Yes Quote Link to comment Share on other sites More sharing options...
TeamRealtreeHD Posted August 15, 2010 Report Share Posted August 15, 2010 Looking for the rubber strips that go on the gas tank up top. Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted August 15, 2010 Author Report Share Posted August 15, 2010 (edited) Looking for the rubber strips that go on the gas tank up top. Sorry no exhaust springs or rubber seals. Here is a general list of what i have. bottom end set of cases steering stem 2 rear shocks 2 front shocks a-arms spindles and rotors front brake calipers rear brake caliper wiring harness 2 radiators 2 clutch covers good clutch basket/inner hub rear grab bar 2 water pump covers flywheel side cover rear linkage a-arm frame with no subframe some misc. stuff im sure i couldnt remeber. If you need something just ask and ill check Edited August 15, 2010 by Mjv420 Quote Link to comment Share on other sites More sharing options...
Jaystre Posted August 15, 2010 Report Share Posted August 15, 2010 how much for the clutch basket? Quote Link to comment Share on other sites More sharing options...
parttimer Posted August 15, 2010 Report Share Posted August 15, 2010 Sorry no exhaust springs or rubber seals. Here is a general list of what i have. bottom end set of cases steering stem 2 rear shocks 2 front shocks a-arms spindles and rotors front brake calipers rear brake caliper wiring harness 2 radiators 2 clutch covers good clutch basket/inner hub rear grab bar 2 water pump covers flywheel side cover rear linkage a-arm frame with no subframe some misc. stuff im sure i couldnt remeber. If you need something just ask and ill check What year banshee did the wiring harness come off of? How much for it? Thanks, Quote Link to comment Share on other sites More sharing options...
340scamp Posted August 15, 2010 Report Share Posted August 15, 2010 What year banshee did the wiring harness come off of? How much for it? Thanks, Hi what condition is the bottom end crank etc chain damage and what all comes with it and price shipped? Thanks Quote Link to comment Share on other sites More sharing options...
dmfisher71 Posted August 15, 2010 Report Share Posted August 15, 2010 Ive got a bunch of stock parts that need to go, if your needing something just shoot me a reply and we'll work something out. Mike i am looking for a set of a arms with good ball joints and would be great if the had good bushings, and a rear swing arm. Quote Link to comment Share on other sites More sharing options...
Mjv420 Posted August 15, 2010 Author Report Share Posted August 15, 2010 how much for the clutch basket? I will let you know tonight. What year banshee did the wiring harness come off of? How much for it? Thanks, 2001, but i spliced the old style connector on it, i did save the original connector but i will have to dig for it. Hi what condition is the bottom end crank etc chain damage and what all comes with it and price shipped? Thanks Rod bearings are tight on the crank, the flywheel side shaft is balloned. Bottom end is together right now, slight chain whack, not bad at all, no flywheel or stator. i am looking for a set of a arms with good ball joints and would be great if the had good bushings, and a rear swing arm. PM sent. Quote Link to comment Share on other sites More sharing options...
eric b Posted August 15, 2010 Report Share Posted August 15, 2010 ill take the inner hub for the clutch... let me know.. Quote Link to comment Share on other sites More sharing options...
340scamp Posted August 16, 2010 Report Share Posted August 16, 2010 I will let you know tonight. 2001, but i spliced the old style connector on it, i did save the original connector but i will have to dig for it. Rod bearings are tight on the crank, the flywheel side shaft is balloned. Bottom end is together right now, slight chain whack, not bad at all, no flywheel or stator. How much shipped to 45320 PM sent. Quote Link to comment Share on other sites More sharing options...
