  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
exhaust springs?
I will check and get back with you
clutch side,, do you have all the gears and stuff on that side? .....let me know
Yes
Looking for the rubber strips that go on the gas tank up top.
Sorry no exhaust springs or rubber seals.
Here is a general list of what i have.
bottom end
set of cases
steering stem
2 rear shocks
2 front shocks
a-arms spindles and rotors
front brake calipers
rear brake caliper
wiring harness
2 radiators
2 clutch covers
good clutch basket/inner hub
rear grab bar
2 water pump covers
flywheel side cover
rear linkage
a-arm frame with no subframe
some misc. stuff im sure i couldnt remeber.
If you need something just ask and ill check
Edited by Mjv420
bottom end
set of cases
steering stem
2 rear shocks
2 front shocks
rear brake caliper
wiring harness
2 radiators
2 clutch covers
rear grab bar
2 water pump covers
flywheel side cover
rear linkage
What year banshee did the wiring harness come off of? How much for it?
Thanks,
Thanks,
Hi what condition is the bottom end crank etc chain damage and what all comes with it and price shipped? Thanks
Ive got a bunch of stock parts that need to go, if your needing something just shoot me a reply and we'll work something out.
Mike
i am looking for a set of a arms with good ball joints and would be great if the had good bushings, and a rear swing arm.
how much for the clutch basket?
I will let you know tonight.
Thanks,
2001, but i spliced the old style connector on it, i did save the original connector but i will have to dig for it.
Rod bearings are tight on the crank, the flywheel side shaft is balloned.
Bottom end is together right now, slight chain whack, not bad at all, no flywheel or stator.
PM sent.
How much shipped to 45320
PM sent.
