I just want to know what it's a normal water temp...
last night, i try my Trailtech vapor on one of my drag bike.
The outdoor temp was around 64F and my water temp was at 150F
after two or three pass.
Too high, low or normal?
This bike water=engine ice.
Your fine up to 220-230 or so. I wouldnt go over 230 deg f. You dont want to run to cold ethire. Find at what temp the bike normally runs at and jet it when it is at that temp. That way you will have optimal perfomance. If you jet it when the eninge is not fully warmed up then when it does warm up it will be rich.
