TIM LUTZ Posted August 10, 2010 Report Share Posted August 10, 2010 What are the shops using? Not the spray can stuff. Doing my painting with an HVLP, Going black over black plastics so I've got that going for me but I do have some deep scratches to fill and that is my next question, What's a good hi build sandable black primer that works well with the promoter if I need to do major sanding before top coating? Thanks Quote Link to comment Share on other sites More sharing options...
toytech Posted August 13, 2010 Report Share Posted August 13, 2010 Bulldog adhesive promoter is good. they use it on plastic car bumpers x2 thats what our bodyshop uses, it is a spraycan though Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted August 13, 2010 Report Share Posted August 13, 2010 I have only used bulldog. Quote Link to comment Share on other sites More sharing options...
toytech Posted August 14, 2010 Report Share Posted August 14, 2010 x2 thats what our bodyshop uses, it is a spraycan though I found out yestureday that it comes in quarts and is also a flexagent Quote Link to comment Share on other sites More sharing options...
FrankieSquid Posted August 19, 2010 Report Share Posted August 19, 2010 Bulldog is a good promoter, used it a few times on bikes i had painted in the past. The one that Duplicolor has is actually pretty good. Gives the paint a smooth finish. Quote Link to comment Share on other sites More sharing options...
Darthwall Posted August 21, 2010 Report Share Posted August 21, 2010 for primer I like to use a good epoxy primer for high build 2K works but most of the time you have to use alot of reducer ore use a gun with a big needle like 1.9 or above. I have used glazing putty in the past for deep scratches and haven't seen any problems yet just make sure its really clean Quote Link to comment Share on other sites More sharing options...
sandtazam Posted September 22, 2010 Report Share Posted September 22, 2010 (edited) In the upholstery world the most used product is called Sandfree. You can get it in liquid or aerosol cans. We use it to dye bumpers, dashes and pretty much anything else plastic. Edited September 22, 2010 by sandtazam Quote Link to comment Share on other sites More sharing options...
C&B Posted September 28, 2010 Report Share Posted September 28, 2010 for primer I like to use a good epoxy primer for high build 2K works but most of the time you have to use alot of reducer ore use a gun with a big needle like 1.9 or above. I have used glazing putty in the past for deep scratches and haven't seen any problems yet just make sure its really clean x2 and Ive never had a prob with Dupont, ever... Quote Link to comment Share on other sites More sharing options...
