2000banshee Posted August 9, 2010 Report Posted August 9, 2010 i recently rebuilt the carbs on my 2000 banshee. It will idle but will not let you get over 1/4 throttle before it chokes out. any suggestions Quote
AKheathen Posted August 9, 2010 Report Posted August 9, 2010 i recently rebuilt the carbs on my 2000 banshee. It will idle but will not let you get over 1/4 throttle before it chokes out. any suggestions is your e-brake on? describe the choking out. does it sound more like a certain rpm, or can you hold it just below 1/4 throttle and let it rev out (it should just about rev out holding it there) if not, then that sounds like the parking brake rev limiter. if it does rev out, then it's in the carbs. describe all you did/changed in the rebuild. did you check the carb sync? Quote
fastquad02blaster Posted August 10, 2010 Report Posted August 10, 2010 is your e-brake on? describe the choking out. does it sound more like a certain rpm, or can you hold it just below 1/4 throttle and let it rev out (it should just about rev out holding it there) if not, then that sounds like the parking brake rev limiter. if it does rev out, then it's in the carbs. describe all you did/changed in the rebuild. did you check the carb sync? No response. You know what that means. I freaked out the first time that I fell for the ol pariking brake rev limiter. I seriously thought that my quad was screwed. Quote
