toddyfresh Posted July 23, 2010 Report Posted July 23, 2010 I got this basketcase shee and building it basically to do some riding in the trails and some open fields.. So far i got ported cylinders with mild dune port, 13t front sprocket, adjust timing plate, fmf exhaust (bike already had it) crank welded, carbon fiber reeds,stock carbs... im not finished yet but i was wondering what you guys think so far as where i should go to next... i havent done nothing with suspension....yet Quote
camatv Posted July 23, 2010 Report Posted July 23, 2010 put it together and ride the hell out of it! Quote
brugal Posted July 23, 2010 Report Posted July 23, 2010 You can bump up your compression/ mill the head or get a cool head. Buy some different size sprockets/ see what gears she likes. And some suspension/ a-arms and shocks. Those few things will make a world of difference. Quote
TIM LUTZ Posted July 23, 2010 Report Posted July 23, 2010 Suspension on the banshee is money well spent. When you start making over 60 horse power the stock setup is just no fun at all to ride. They just din't turn well enough to miss that tree that comes up a lot faster with motor mods. A 1.5" shorter aftermarket 250r type swing arm and A arms that set the front wheel 2" foward and make the front end 4" wider with a 4" wider axle, good tires and at least aftermarket shocks up front will make SO much diffrence on the Shee. Quote
toytech Posted July 24, 2010 Report Posted July 24, 2010 put it together and ride the hell out of it! x2 Quote
