I wont bore u with all my nightmarish problems ive had during this build. long story short, there is a hair-line crack on the bottem case right beside the drain plug thats leaking..... what is my best course of action.....????
JB weld or spend the many and have it welded at a machine shop by someone who knows how to weld aluminum.
do i have to disassemble it before it can be welded??
Yes. It would be the smart thing to do. That way it can be possibly welded from the inside to.
thats kinda what i was thinking. will a crack that small affect the strength of the case??? its a 421....
I had the same thing on my case . I welded it up with out pulling the motor down. Just drain the oil & clean the case really good & drilled out the ends of the crack to stop it from getting bigger. Then I welded it up. I use a MIG with aluminum wire.
Did you drill right through on each end or just a indent type of thing? cause if you drilled right through id be worried about the particles...
Yes I did drill through. I just put grease on the drill bit. That keeps the chips from going inside trans. Then I just flushed it out with parts cleaner. GOOD TO GO. I have not had any problems with it. That was about a year ago.
I would take it apart to weld it for a few reasons. 1 to check for more cracks and like already stated weld from the inside if possible. 2 you run the risk of burning the oil and having chunks of burnt oil floating around in your case. If it is taken apart you can clean them out first. I would get it tig welded too it is much cleaner looking and no spatter. Mig would be fine too though just not as nice
well thats a brave way to do it... abit of a sketchy way to do it with drilling right through and so on...
though flushing the engine a few times usually does the trick most of the time...
Yes you are right it is sketchy. :unsure: But it worked, It did take me some time work up the balls to drill it. But it did save me a tear down. Also grease on the drill & a good flushing is the key. I flushed it to a clean can & there was no chips. :dance: When it needs a rebuild that will tell the truth if it was all worth it.
Your a lil far but if your in a pinch ill hit with the tigfree of charge but shipping might kill you ,and time factor,just saying if you cant find any one good hit me up.Have you ever thought of marinetek epoxy,its good shit and what alot of builders use to epoxy cases
