toddyfresh Posted July 11, 2010 Report Posted July 11, 2010 hey guys getting back into banshees fairly new to this.. got a basket case that had botom out and smashed case and crank so i got a used bottom end off of hee with hot rods crank and here is a list of what else i bought seeing what you guys think should be next 1.bottom end with hot rods crank 2.t5 pipes 3.adjustable timing plate 4.The bike has new pistons that are .20 over with porting done just gonna get new rings bore is nice but not sure what kind of porting 5.bike had kn filter with stock carbs. 6.also had vforce 3 reeds but peddle is ripped think i should just get new peddles\ 7.got new clutch where would u guys go from here? tihinking maybe different head?thank u Quote
T_Shee Posted July 11, 2010 Report Posted July 11, 2010 cool head wouldnt be a bad ideal. but the first thing i would do is check everything else out on the bike. check every bearing and bushing, brakes, pivot joints, etc. you can spend a ton of money on upgrades then go out riding and break down because of a minor general maintnance issue. once you check all that out then maybe buy a head and some good rear tires (depending on what yours are like). as far as reeds, the replacement pedals for the v force are pretty expensive. you could prolly sell them and pick up a set of stock cages with boyesen dual stages and maybe come out ahead. Quote
