NOVIS Posted June 29, 2010 Report Posted June 29, 2010 my front wheel bearing were completly done so i ordered new ones. i was taking out the old bearings and seals and when i got to the last bearing the bearing and everything popped out but the outer ring of the bearing stayed in. it seems to be completely corroded and attached to the inside of the hub. i have grinded parts of it. tried chiseling parts of it out and it seems like completely stuck. so my big question is will a warrior front hub fit ona banshee. i can get a warrior hub cheap and quick but nobody around me is parting out a banshee. Quote
bansheesandrider Posted June 29, 2010 Report Posted June 29, 2010 Try heating the hub with a torch and letting it cool, then see if you can drive the race out. And yes Warrior hubs have the same part number as Banshee hubs, at least for a 97 model. Quote
12 0 Clock P I M P Posted June 29, 2010 Report Posted June 29, 2010 Try heating the hub with a torch and letting it cool, then see if you can drive the race out. And yes Warrior hubs have the same part number as Banshee hubs, at least for a 97 model. YOu need someone with a press and it will come right out! don't go breaking anything Quote
NOVIS Posted June 29, 2010 Author Report Posted June 29, 2010 Try heating the hub with a torch and letting it cool, then see if you can drive the race out. And yes Warrior hubs have the same part number as Banshee hubs, at least for a 97 model. ok thanks. ill try and pick a warrior hub up as soon as i can, if it doesnt fit i can take it back, i bought stuff from the guy before and he said if anything didnt work right then i could come and get my money back. Quote
