Oil Leak thread
here is a link for the situation. There are also some pics of the studs that are leaking
After exploring under my banshee a little more, I believe my under body of my case on the left side seems to be welded. Can anybody verify if this looks right or what the next action should be?
http://s815.photobucket.com/albums/zz79/supermdub/?action=view&current=013.jpg
these are the leaking studs, what are those holes for under the engine? They were full of grime before I emptied it
http://s815.photobucket.com/albums/zz79/supermdub/?action=view&current=015.jpg
idk what to think about it, is it supposed to be like that?
Def looks welded and epoxied. If you cant get it to stop leakin, get a new set of cases and bring it over with some beer and ill show you how to tear down and rebuild your bottom end :cheers:
Well smurf..... to me it looks like some chain whack has occurred. Some one followed it up with epoxy from the looks of it in the pix. Geez i better get a case saver for my new bike! Actually, ur in michigan right? Just hop on ebay and look up komisar motorsports. Call him and go check the stuff he has shelved. Super chill fella with good prices.
i cant tell from those pics what looks to be welded if anything. are you sure its coming from the studs. is up by the sprocket wet. could be the netrul sover leaking. and coming down on the underside. or it could be the shift shaft. looks like a whole peice of metal is missing like a chain came off and broke it off. the nnetrul cover and sprocket is too exposed right there. .
im from ny. A lot of my underbody of the cases have oil leaking. I didnt know what it was supposed to look like, first banshee. If you would like me to take a pic of a different angle or area I could do that.
Im just trying to figure everything out, I thought I had been pretty close to finishing my rebuild then I started putting fluids in and drippage from multiple places. The nuts/studs from the first pic and that area that looks welded.
There are two holes under my engine, one you can see in the first pic above the two studs/nuts. What are those for?
looks like i see coolent as well as trans fluid.
they can be welded but depends on the damage your need some one knows what they are doing to have a look at it
can anyone let me know what i will need when i switch cases as far as other stuff to buy. I know Im going to purchase an oil seal kit from F.A.S.T. I have blue thread locker and yamabond 4 already. What else would be a good idea to replace while I have her gutted
