hi guys,
i have some carb and jetting questions , i have been reading your posts and y'all have a tone of experience and good advice .
my questions are , well lets start with this i have the stock carb in my quad and i have some Mikuni 34mm flat slide that i want to put in
engine has dune port stock bore -vforce 3 - cool head 21cc 155 comp- t5 pipes - k&n filter
stock carbs
-main jet 290
-pilot 25
i want to install the mikuni 34mm
where should i start for my jets and air screw
also what will my gains be ?
is it worth it
do i need +4 timing ?
thank you for any help
hi guys,
stock carbs
-main jet 290
-pilot 25
is it worth it
no help ?
am i in the wrong forum ?
I'm running the same carbs, on a stock stroke 4 mil, with CPI's, porting, and pods.  I'm running a 300 main, and I can't remember what size pilot.  I think the 34's are going to be too much carb for your setup.  Try some 28mm, or 30mm carbs.
ok cool
so when would i need to go to 34mm carbs ?
what determines going to a bigger carb
and what are pods
thx
Edited by sheeforever
Pods, are K&N clamp on filters.  You use them when you ditch the air box.  You really won't need the 34's, until you go to a stroker crank, and in frame drag pipes.
thanks for your help
will the 34s work fine or are really not the right carb at all i have them with intake and pods didn't pay any thing got them from a friend , my stock carbs are in bad condition the threads on the slide caps are stripped and need to be replaced
it has a noss cool head and im going to put 19cc domes in and run race gas , i run 50/50 now
They will probably be tough to get dialed in, since they are really more than you need, but they'll work.  I'm not sure where you'll want to start jetting wise.
so i will get more performance out of 28-30mm carbs
thanks Fast you have been a great help!!!
Aaron
The 340 will be way rich for your setup. I'm running a 300, and I've got more motor, CPIs, and porting. Try starting with a 300, and jet down.
so what do you think of 2 into 1 ?
