Guys, ive been posting about my 485 im building and lots of folks helping me out, thank you!
ive got a simple poll for the trinity cheetah users... can you post what you have for a setup like the one below...Im interested to see what combo folks are running. If your not sure about all the items list as much as you can. Thanks a bunch, should be interesting
485
mild porting
150 PSI cold compression
27cc domes (stock trinity un-modifyed)
.050 squish
stock trinity semi dome pistons (not flat top)
93 ocatane gas
elivation 800ft
timing adavance 0
Edited by lt1bird
It is not completely together yet, but this is pretty close to what it is going to be. It should be running within 3 weeks.
421
porting cleaned up
22 (ish) cc domes........running it at 12:1
0.045 squish
92 octane pump fuel
900' elevation
timing advance 4 deg. (maybe less)
Rocket pipes - first gen.
33mm Mikuni flatlside carbs from an SRX700
pulse fuel pump
6" K&N's with outerwears
V-Force 3's
Tusk HD clutch for now.......lockout if it doesn't hold.
It's just my trail bike :)
Edited by Valin
mine are not trinity but are cheeta's
485 cheeta
my custom porting ( for pv's)
250r custom reeds ( 4 stage)
one piece custom cut head old cast style moddified stud holes ( larger so o-rings seal better) .52 squish thin band, flat dome style
1-5 override, polished and smoothed
lockup with billet basket with hardened rear plate and big bolts
fully welded 4 mill long rod HOTRODS crank with tz drive bearing
trenched and filled cases for larger base of cylinder
port matched pv's and pv plugs ( i run both at times)
UPP intakes
41.3/44mm packard alky carbs
accel coil
stock CDI
+12 timing
shear pipes
will wheelie a lsr frame with my 270lbs ass on a +14 arm. love this motor
also have a 535..
Edited by camatv
