yeahitsmine Posted June 22, 2010 Report Posted June 22, 2010 hey guys I was wondering if I can get some help on installing a new clutch on my shee I was also wondering what is the rubber rings for Quote
shee2000 Posted June 22, 2010 Report Posted June 22, 2010 (edited) clymers manual will b ur best friend but there not that hard if i remember correctly when u take off the 6 clutch bolts u take them out in equal turns all the way around then the same when reinstalling it n make sure to keep track on how the clutch came apart n put it together the same way and soak the clutch plates for a few minutes before installation Edited June 22, 2010 by shee2000 Quote
firebanshee Posted June 22, 2010 Report Posted June 22, 2010 hey guys I was wondering if I can get some help on installing a new clutch on my shee I was also wondering what is the rubber rings for Throw them rubber rings away,they are for dampening you don't want them.Pre soak your clutch disks and deglaze the steels if you are not putting in new ones.Do not over tighten the 6 bolts that hold the springs in,the towers they screw in will break off EASY. Quote
