Banshee Compression
HI guys ! I'm new here and I have a question for you !
- I've just done a compression test on my both cylinders, and the result was around 90 P.S.I. on Std. bore (64mm)
do I need to rebuild to end with new pistons and rings ?
Thanks !
Thanks !
Again, what tester did you use?
I have to tell you this - double check with another tester before you do anything expencive.
This is what happened to me 1 year ago.
I ordered my first mods for my banshee and after that I was thinking what was my compression.
I bought a tester and it showed 55 and 65, I was like WTF?! I went with my tester to a local shop that maintain 2 stroke bikes.
They compared it to one of them testers and said that my tester was NO GOOD and I should return it back - so I did.
I bought another one and it showed 110 and 115. I was thinking that thats the way it should be but it´s low.
I called to a good friend of mine and he told me that it might be a good time to bore it and also to make a port job and shave my stock head at the same time.
After a long research and studing of porting and waiting my parts I was finaly done - 8 months later!!!
My motor was back together and everything was good so I finaly go to break it in. After a good break in I was thrilled! Sounds great and stuf like that.
Next thing was to check how high was my new compression... 125 and almost 125!!!! HELL YEAH! THE SECOND TESTER WAS LEAKING!
- Now my motor runs great but I did all that shit because of my bad tester.
DOUBLE CHECK - before you put your Visa on-line!
-Pasi S.
(sorry my bad english)
...OH! and I went from the bone stock to mods in my sig. LOL!
Edited by Pasi S.
