Ok so I am a dumbass and could use some help with my shee. I have a problem with the spark. I have spark just not every kick. Its like every third or fourth kick she sparks. it hits and sometimes fires then dies. the pickup coil and stator Resistance tested ok and I just replaced the ignition coil. the gap between the pickup is set and I tried it closer and farther and still the same. the magnets seem real weak to me but I have nothing to compare it to. I am thinking the magnets or maybe the stator are causing this. Akheathen tried explaining how to test the stator in the shout box to me but I couldnt understand. I have a fluke meter to use just not real sure what to do.
any help would be appreciated
thanks
Dillon
thanks
Dillon
Sounds like the CDI is bad. Here is a link on how to test the stator
Edited by pr0blumz
I had the same problem as you described and my CDI was the cause. Do you have a friend you can get one from to test on your bike?
Edited by pr0blumz
that exact scinario is from weak current feeding the cdi- it takes about 3-4 kicks fot the cdi to build up enough power to fire, whereas it should be building it in 1 kick, and every revolution. only thing that does it is weak flywheel, or power from the wingings, which can ba a wirirnf connection in the harness, or even at the cdi plug. take your readings at the cdi and see ehat you come up with, then wiggle wires and inspect the plugh connections to find and issue there
